Topic: Music limiter
Hi all
Dj last night and have the latest update 8.2
But had lots of problems. Vdj froze and had to control alt delete to close program a few times
Also the music would drop down in volume like the limiter was pulling it back
Using hurcules Rmx 2
I'm using mackie 450 and 1801 sub.
Had the master up and silders down low. As normal the way I have used it for years
Only thing I noticed kept defaulting back was the filter volume. Not sure what this is for
Version 8.2 seemed a bit unstable
Can I go back to version 8.1?
Thanks
Jason
geposted Tue 02 Aug 16 @ 1:12 pm
geposted Tue 02 Aug 16 @ 2:20 pm
The Magic.DJ wrote :
http://www.virtualdj.com/download/build.html
Thanks Magic
geposted Tue 02 Aug 16 @ 8:00 pm
