Topic: Need feedback on new mapper for HDJ Instinct, tons of features so far.
Here is my (mostly finished) mega map for the Instinct, I used the awful pitch paddles as a double shift system to give a huge amount of possible buttons and this is everything I worked out so far. LEDs are mostly working as I didn't have to change much there. Please check it out and let me know what you think and how I can improve it for general use.
Link removed
2 shift modes: Pitch paddle up (shiftup) and pitch paddle down (shiftdn), requires Pitch Repeat Frequency and Delay to be set to 10ms in the Instinct Control Panel.
Mixer Section:
EQ High:
(noshift) eq high
(shiftup) effect 4 slider 1 and activate effect 4 when away from 50%
(shiftdn) effect 1 slider 1
EQ Mid:
(noshift) eq mid
(shiftup) filter resonance
(shiftdn) effect 2 slider 1
EQ Low:
(noshift) eq low
(shiftup) filter
(shiftdn) effect 3 slider 1
Vinyl:
(noshift) vinyl mode
(shiftup) undefined
(shiftdn) undefined
Browse -/+:
(noshift) move 1 line
(shiftup) move 10 lines
(shiftdn) move to beginning / end of list
Folder:
(noshift) go to folder / expand and collapse folders
(shiftup) clone deck b to deck a
(shiftdn) go to sidelist
Files:
(noshift) files
(shiftup) clone deck a to deck b
(shiftdn) copy file to sidelist
PFL A/B:
(holding) reset eq and filter, all effects off
(noshift) pfl
(shiftup) toggle aux in
(shiftdn) reset eq
Load A/B:
(holding) unload
(noshift) load
(shiftup) prelisten
(shiftdn) analyze file
Transport Section:
Play/Pause:
(noshift) Play Pause
(shiftup) Play stutter
(shiftdn) dump (slip + reverse)
Cue:
(noshift) cue stop
(shiftup) cue play
(shiftdn) stop
Jogwheel:
(noshift) Pitchbend
(shiftup) undefined
(shiftdn) fine adjust CBG
Touchwheel:
(noshift) scratch / bend as per vinyl mode
(shiftup) undefined
(shiftdn) undefined
Tracking <</>>:
(noshift) -/+ 1 beat
(shiftup) -/+ 1 bar
(shiftdn) cbg downbeat -/+ 1 beat
Pitch Section:
Pitch -/+:
(noshift) pitch -/+ 00.10 %
(shiftup) pitch -/+ 00.01 %
(shiftdn) pitch -/+ 01.00 %
Sync:
(noshift) sync
(shiftup) loop off or new loop at current location with default length
(shiftdn) tap
Multifunction buttons:
Cue buttons:
(noshift) set cue / cue if set
(shiftup) if cue set jump to cue and new loop at default length
(shiftdn) delete cue
Loop Buttons:
(noshift) 1. loop On/Off, 2. reloop, 3. halve Loop, 4. double loop
(shiftup) quick loops (1/4, 1/2, 1, 2)
(shiftdn) quick loops (4, 8, 16, 32)
Effect Buttons:
(noshift) toggle effect
(shiftup) loop roll (1/8, 1/4, 1/2, 1)
(shiftdn) undefined
Sample Buttons:
(noshift) trigger sample 1-4 (5-8 on deck B)
(shiftup) stop sample
(shiftdn) 1. bank -1, 2. bank +1, 3. stop all samples (both decks) 4. undefined
geposted Wed 03 Aug 16 @ 9:17 pm
Please don't share Mapping files or any other VirtualDJ Addon using 3rd party links. Link to file has been removed.
The description you provided is good enough to get feedback. If you need to share your mapping file (or any other Addon), please upload here and let Team to review and approve.
geposted Thu 04 Aug 16 @ 10:22 pm
My apologies, I will upload the mapper soon for approval.
geposted Sat 06 Aug 16 @ 2:08 pm
