while manually entering some FIRST SEEN tags of some songs...i realized that the month field, if the month is single digit for example, this month,(08), while entering, u can only type in 8...not 08, if u type in 08,the tag does not save...i know this may be unimportant..but i think it should be corrected....
i was copying some first seen tags with a date like 2014/07/23,for example and realized that when i pasted the tag in the example,it did not save...the day field seems to be working though,like if the date was the 2nd,u could type in 02 and it will work....i havent checked the first played field as i hardly use this...thanks in advance....
geposted Thu 04 Aug 16 @ 11:51 pm
You are correct. Reported and will be fixed soon.
Thank you for the feedback.
geposted Fri 05 Aug 16 @ 6:28 pm
no problem!
geposted Fri 05 Aug 16 @ 8:39 pm
