Topic: build 3324 File operations Rename bug
Hey all,
in 3324 when using file operations... rename to rename a folder from the left pane (directories) it is impossible to rename a UPPERCASE folder to a lowercase or Sentence Case folder.
geposted Sat 06 Aug 16 @ 11:58 am
Thanks for the feedback. Reported and a fix will be provided soon.
geposted Sat 06 Aug 16 @ 4:13 pm
