I'm have some major problems with using my gemini cdj 700's with the last two updates. First off I can use the cdjs not it will not show any song info or timing on the screens anymore. How can I fix this and not have to Uninstaller vdj 8 and reinstall it?? I have almost 2TB of songs that are all analyzed and playable. I'm using the pc verison of vdj 8 on an asus laptop with Windows 10 and an American audio mxr14 and 2 gemini cdj 700 decks. Help please!!
geposted Sun 07 Aug 16 @ 4:52 am
Is this still happening with the latest build 3343 ?
geposted Sun 07 Aug 16 @ 3:43 pm
Problem has been solved. Had to do a firmware update to the CDJ-700's to get them to work correctly.
geposted Tue 23 Aug 16 @ 8:24 am
