Topic: howto: Map Line Input to deck?
I have a Reloop Terminal Mix 2 Controller, which has a Line/Phono Input.
I don't understand, how to map this input to a deck i.e. Deck 3 in VDJ 8.2.
Any help is much appreciated.
Thanks
Thomas
geposted Sun 07 Aug 16 @ 9:35 am
If not mistaken, there should be a switcher at the front side to set the Input to SW or MST. It should be in the SW position.
Then you will need to add a linein line in your Audio setup
linein .... Reloop sound card (probably ASIO) .. chans 1,2
Click APPLY
Once the linein is added to the audio setup, the default skins should offer AUX buttons. When enabled the Input should pass to the deck that is was enabled and you should get LineIn as Deck's Title.
If you need to map a button to route the linein specifically to Deck 3, you can use ..
deck 3 linein
but you should also get AUX buttons in the Scratch panel of the default 4 Decks skin
The Terminal Mix 4 has a similar audio setup and functionality. Take a look here .. http://www.virtualdj.com/manuals/hardware/reloop/terminalmix4/advanced.html
geposted Sun 07 Aug 16 @ 3:16 pm
Thanks DJ Dad,
and sorry for the delayed response.
I'll give it try...
geposted Sat 13 Aug 16 @ 7:25 am
