Topic: Midi Controler Just stoppped working?
NuzzletPRO InfinityMember since 2015
I have a midi controler that is built for Ableton Live. I use it there every day. Today, I launched virtualdj. I have created a working mapping and device xml for the device. It worked yesterday, but today, the controler just sits there. Nothing happens, no lights or button responses. It does still work fine in the other software. I think it stopped working sometime after I updated virtualdj.
geposted Tue 16 Aug 16 @ 4:39 pm
Custom definitions require a Pro Infinity License
geposted Tue 16 Aug 16 @ 4:42 pm
I thought you had 10 minuetes? It was like that yesterday before I updated.
In the virtualdj controler config:
When I press a button on the controler, it says that button was pressed. I tried to re-map one of them, but that isn't working. So Its has somthing to do with the new controler mapping system? The UI seems to have changed.
Why is it not working?
geposted Tue 16 Aug 16 @ 4:45 pm
