Topic: MC6000 EFX button configs with VDJ 8.2
I used to have the EFX (4 of them) buttons for each deck programmed for the following effects:
EFX1 - Beat Grid
EFX2 - Loop Out
EFX3 - Backspin
EFX4 - Brake
The controller Denon DN-MC6000 selection appears to show the proper actions, but the buttons aren't working. For example, the action for the left deck EFX1 shows:
EFX1_BTN_LEFT
effect 'beatgrid' activate
The button doesn't light up and the effect isn't working. Any suggestions please?
geposted Sat 20 Aug 16 @ 2:48 pm
That's v7 syntax,
effect_active 'name'
Check the mapping window it gives the full syntax as you'll need to include slot assignment
geposted Sat 20 Aug 16 @ 2:55 pm
locodog wrote :
That's v7 syntax,
Can you help me? What do you mean check the mapping window?
geposted Sun 21 Aug 16 @ 4:14 pm
the controller section, where you do the mapping, where you assign script to buttons.
geposted Sun 21 Aug 16 @ 4:27 pm
I found this helpful video:
https://www.youtube.com/watch?v=vKm0vdj7xxk
At 5:00 in the video, he shows how to program a button (on a different controller) to the backspin effect. That's one that I'm wanting to map for my MC6000 EFX button:
Old VDJ7 syntax:
effect 'backspin' activate
VDJ8 syntax:
backspin
Yet, the button still does not light up nor does the effect work.
Still trying...
geposted Sun 21 Aug 16 @ 4:39 pm
geposted Sun 21 Aug 16 @ 4:55 pm
I sure do appreciate the replies to help me. I tried that last one, but still no luck. But I'm checking out that reference you listed, it's a good one.
geposted Sun 21 Aug 16 @ 5:11 pm
Anyone have any other suggestions as to the proper syntax to get the Denon MC6000 EFX buttons programmed?
geposted Sun 21 Aug 16 @ 10:19 pm
effect_active 1 'beat grid'
effect_active 2 'loop out'
effect_active 3 'backspin'
effect_active 4 'BrakeStart'
geposted Mon 22 Aug 16 @ 3:26 am
