Topic: Loop Out plugin issue?
Early access build 3390 - Loop Out plugin is having issues playing nice with it - half the time It works and half the time it does a complete audio drop out instead of looping out with audio.
currently trying other plugins to see if this issue involves others
geposted Thu 01 Sep 16 @ 11:33 pm
I have the same problem but it's been for every build.
geposted Fri 02 Sep 16 @ 7:18 pm
rolling back to public build fixes it... interesting.
geposted Sat 03 Sep 16 @ 8:48 am
What controller do you use and what sample rate is it set at ?
geposted Sat 03 Sep 16 @ 9:48 am
no controller. and same behavior at club and at home. rolling back to current public build fixes it
geposted Sat 03 Sep 16 @ 10:11 am
I can't remember what it's set on at the club, but I believe I have it set the same as on home machine - 48.0k 22.0ms 2o that's if i'm looking in the correct place
geposted Sat 03 Sep 16 @ 11:01 am
at club now and soundcard is 48.0k 30.0ms 4o
going to try installing public build for the night.
geposted Sun 04 Sep 16 @ 12:31 am
freppaPRO InfinityMember since 2002
geposted Sun 04 Sep 16 @ 4:46 am
I've had this exact same issue :(
geposted Sun 04 Sep 16 @ 4:02 pm
have no fear gent's - last night went flawless after rolling back to b3343. I was going to go to 3384 but just took easy way and will wait till after next update to play with early access again.
geposted Sun 04 Sep 16 @ 6:56 pm
