I am using 8.2 on a MacBook Pro retina. Was using Bootcamp but last weeks crash has put me off so going with El Capitan this week.
I mostly use Vob files which are 48000 but when I change this setting, it doesn't remember it and keeps reverting back to Automatic 44100. Any ideas?
geposted Fri 02 Sep 16 @ 6:06 pm
geposted Fri 02 Sep 16 @ 6:36 pm
I've tried selecting it with the pulldown menu, still reverts back to it as soon as I come out of the settings menu.
geposted Fri 02 Sep 16 @ 6:41 pm
You may have to go into the Audio MIDI setup program on your mac then and change the samplerate there instead of from within virtualdj.
geposted Fri 02 Sep 16 @ 6:58 pm
Thanks for the replies - how would I do that? Not sure!
geposted Fri 02 Sep 16 @ 7:02 pm
In spotlight start typing "audio midi" and it should come up.
From there, select the device/sound card you are using, and change the samplerate to 48000
geposted Fri 02 Sep 16 @ 7:04 pm
Yup follow Adions advice, helped me out a ton.
geposted Fri 02 Sep 16 @ 7:11 pm
Thanks - done that for Internal Speakers. I'm using a Mixdeck Quad though so USB Audio - will that show in there when it's connected and will I have to change it for that? Just thinking now, maybe when I connect it up later it would allow me to save the setting in VDJ for the Mixdeck Quad... Will feel a fool if it does...! Can't test it yet though!
geposted Fri 02 Sep 16 @ 7:12 pm
Maybe the Mixdeck Quad isn't capable of working at 48000 and that's why it changes back.
It may be a hardware limitation. Considering the Quad plays CDs I would say that 44100 would be most likely.
geposted Fri 02 Sep 16 @ 10:40 pm
My research concurs. 44.1KHz
geposted Fri 02 Sep 16 @ 10:53 pm
Yes, you are correct. Just tried the audio setup with Mixdeck plugged in - 44100 only.
geposted Sat 03 Sep 16 @ 1:24 am
