Topic: Extreme latency, 8.2 3398.1227
I do a lot of scratching, and on this build (I just moved from 8.1, which worked flawless), the right deck specifically has become extremely delayed. It doesn't happen right away. When you dj for a while, it all of sudden gets like that and it stays like that until you restart the software.
using windows 10, 16 gigs ram, 2gb dedicated video, i7
geposted Sun 18 Sep 16 @ 2:56 pm
instead of restarting try click apply on the audio config, just a hunch I have.
geposted Sun 18 Sep 16 @ 3:03 pm
