Hello, so because of Pad support, I have decided to use the default skin. My biggest problem is that I use Mixed In Key. I don't like or want to see VDJ keys. I have a great script to show what I want to see, but I fear there is no way to modify the factory skin Key section to look at the Comments field instead.
It would be great if VDJ did not ignore the stored Key tag value and over write the key with it's own scan results. That would be fixing the problem at it's start!
geposted Thu 22 Sep 16 @ 12:21 am
Ah, just found "Use Key From Tag"! Appears that has been addressed. Now no need to modify skins. Very happy camper. Now I just need a way to show energy level.
Thank you for adding Use Key From Tag! Seriously! Thank you
geposted Thu 22 Sep 16 @ 12:28 am
