Topic: vitrtual dj 8.2 vms4.1
Using Virtual DJ 8.2 & an American Audio VMS4.1 controller, whilst playing a song on deck 2 & loading a song onto deck 1 with quite a bit of BPM difference, Deck 2 automaticly speeding up through the software only, even with controller pitch set at 0. This has happened quite a few times & only happens on deck 2, was doing a wedding & about 6 times it speed up by it's self (Sounding like Alvin & The Chipmunks. Have gone into options & having to reset pitch range (Normally set at 12%). In settings the Auto BPM & Auto Pitch Range are disabled. Never had this problem with Virtual DJ pro 7. Any help would be great.
geposted Thu 22 Sep 16 @ 12:11 pm
Did this happen when you played Deck 1 or just when u loaded that ?
Maybe Beatlock is enabled on deck 2 ? Check the SCRATCH center panel.
geposted Thu 22 Sep 16 @ 4:01 pm
It happens when I press the play button on deck 1(on controller) when cueing through headphones...not all the time but every so often, but it's only speeding up on Deck 2 & not Deck 1, been into all settings & auto bpm & auto pitch are disabled so am stumped.
geposted Thu 22 Sep 16 @ 4:40 pm
