Hi all, new to VDJ and having a newbie problem; I'm sure there is something simple I'm missing. Many thanks for any help/advice in advance :-)
I've set up a beatgrid for a track that has variable bpm with multiple grid markers (not more than +/- 5bpm) - I want to sync this track to the master channel which has a loop with a known fixed bpm playing.
Everything works as expected until i reach a marker in the grid where the bpm changes, then i need to press sync again to reset the bpm to the value of the master channel, otherwise the bpm value changes and no longer matches the master, eventually going out of sync. (edit - not using any controller, just keyboard and mouse)
Is there a way to get vdj to stay locked on the bpm of the master channel when it encounters a change in bpm in the tracks grid?
hope that make sense! thanks..
geposted Thu 29 Sep 16 @ 4:34 pm
Try to enable Beatlock for the deck you want to always stay on beat from the SCRATCH panel
geposted Thu 29 Sep 16 @ 8:53 pm
that did the trick, thank you very much :-)
geposted Thu 29 Sep 16 @ 10:16 pm
