Hm, I am confused.
In earlier versions of VDJ there were two buttons in BPM editor that let me adjust the beat number. In some songs the BPM is detected correctly but not the "1" on a measure, like the "2" is actually the "1". So it was easy to click on those buttons to change the beat number. However the buttons seems to be gone in the lastest versions.
I also tried setting a beatgrid anchor in POI editor and gave it the number "1", but that does not change anyting, the beat is still off by 1/4.
Any ideas? Thanks!
Any ideas? Thanks!
geposted Wed 12 Oct 16 @ 8:24 am
The easiest way to do that is to map a custom/keyboard button as:
adjust_cbg -1
adjust_cbg -1
geposted Wed 12 Oct 16 @ 10:44 am
You can do it in the BPM Editor, button group 11 in the manual:
http://www.virtualdj.com/manuals/virtualdj8/editors/bpmeditor/index.html
geposted Wed 12 Oct 16 @ 12:22 pm
Ah I found out what happened. I clicked accidently on Variable BPM, and if you do that the < and > buttons dissapear. I also could not find a way to get them back, only closing BPM editor and reopen it works.
Thanks for your suggestions!
geposted Wed 12 Oct 16 @ 9:09 pm
