Example I have a few unused buttons on my control and I want one to start and stop the Video Visualization. So, hit the button to Start Spectral, hit the same button to stop it.. using the mouse in a High energy club is TERRIBLE . Am I able to do this and whats the midi code? Nothing I tried works
geposted Mon 17 Oct 16 @ 2:40 am
I can't even get a mac keyboard key to do it. It will turn it off if on but that's it
geposted Mon 17 Oct 16 @ 4:04 am
Which script are you using now?
geposted Mon 17 Oct 16 @ 6:11 am
I used the dropper thing to get the script but i also chose it in the options. And it won't work. As I said. Turns it off but will not turn it on. Even a keyboard short cut would work I'm not at my system right now but when I am I'll grab the script
geposted Mon 17 Oct 16 @ 6:33 am
show the actual script
geposted Mon 17 Oct 16 @ 7:15 am
The only way to turn off a Visualisation is to set it to "None" .. so try ..
setting 'VideoAudioOnlyvisualization' 'Spectral' ? setting 'VideoAudioOnlyvisualization' 'None' : setting 'VideoAudioOnlyvisualization' 'Spectral'
should toggle between Spectral and "Off"
Also keep in mind that you cant turn this On when a Video file is playing. The Visualisation will be used only when Audio files are playing, so if you wish to activate the Spectral Video Effect at will, you need to use the .. deck master video_fx 'Spectral' action
geposted Mon 17 Oct 16 @ 1:47 pm
If you just want to manually trigger a visual (not automatic only for audio-only tracks) you should be able to just use
deck master effect_active 'Spectral'
geposted Mon 17 Oct 16 @ 2:50 pm
Ok.. all that is a little confusing which is fine. Lol I'll mess around with a few of these ideas to see what I get. Thanks
geposted Mon 17 Oct 16 @ 6:23 pm
I use spectral as well and i activate it with one button. What i did was simply set it as master deck effect and map a button on that. No need for coding. i can activate up to 5 effects that way. 3 single deck effects and 2 master effects.
geposted Mon 17 Oct 16 @ 6:57 pm
THIS is what Im looking to do!
geposted Mon 17 Oct 16 @ 7:14 pm
Depending which skin you are are using, simply set the master effects that you want and follow this guide.
https://youtu.be/vKm0vdj7xxk
See how he makes a button to become loop_in ?
All you have to do is find the button you want to use on the controller, go to the right where that magnifying glass is and click on the master deck effect.
That's how I've done it.
And if you want to use 2 effects on the same button (on your controller) you can use it with the shift button (only if your controller has one)
For example.
Your script will look like this in the beginning.
Master effect 1
If you want to use 2 effects then it will be like this:
var '$shift' ? Master deck effect 1 : master deck effect 2
For example.
Master effect 1
geposted Mon 17 Oct 16 @ 7:27 pm
AWESOME I got it and I also remapped a few other Serato only buttons on my SX2 to do other things. I now and all buttons back in use on my controller and you guys helped get that started Thanks.
geposted Tue 18 Oct 16 @ 5:37 am
You'll never be happy with default ever again. :-)
geposted Tue 18 Oct 16 @ 6:29 am
There are a lot of videos to check on YouTube for more tips and tricks. Thing of virtual DJ as a program with unlimited stuff that you can customize.
geposted Tue 18 Oct 16 @ 2:22 pm
Which in my opinion makes it the best DJ software out there
geposted Tue 18 Oct 16 @ 6:04 pm
