Topic: BUILD 3440 (2016-10-08) need explanation
lincol2PRO InfinityMember since 2011
"Sampler_loop action accepts loop length and can be used while pressed"
Can someone please elaborate more on this, like a scenario this can be used ? How to use...while pressed?
There are a ton of good improvements in your build, but for a idiot like me will need help to figure what "they are talking about". P
geposted Sat 22 Oct 16 @ 1:12 pm
Before you could only halve or double the sample play length, so say a 8 beat sample you could cut it to 4 beats then 2 beats only in steps, all you could script was 'sampler_loop 1' or -1 now you can miss the steps
sampler_loop 3,
I think while pressed should make sense now.
geposted Sat 22 Oct 16 @ 1:26 pm
