I am unable to export cue points from Mixed in Key (MIK) to VDJ8 . The cue points do not appear when the song is loaded in the grid.
However,all other tag info such as key, energy,bpm is ok.
I have tried everything in MIK, as well as re-analyzing the songs but still the cue points do not appear, can you help me resolve this.?
geposted Sun 23 Oct 16 @ 10:28 am
What is your getCuesFromTags set to?
geposted Sun 23 Oct 16 @ 10:37 am
geposted Sun 23 Oct 16 @ 10:39 am
The getsCuesFromTags set to yes.
I am using VDJ 8.00 build 1949.790 ,
geposted Sun 23 Oct 16 @ 10:59 am
Unfortunately I am unable to see the exported cue points . Is it possible with Vdj ver8.0? Is there any bug associated with this version?
geposted Sun 23 Oct 16 @ 11:34 am
Use a upto date build, you'll get zero support as a home licence user using a build well over a year old,
honestly it screams piracy, it might not be the case but that's the way it looks.
geposted Sun 23 Oct 16 @ 11:36 am
ok thanks
geposted Sun 23 Oct 16 @ 11:51 am
