My question is, let's say i will connect ddj sz to the new macbook pro with usb c to usb b cable will it work ?
Thinking of any communication problems ?
geposted Fri 28 Oct 16 @ 3:29 pm
Shouldn't be any problem. USB 3 is backward compatible with USB 1 and 2
geposted Fri 28 Oct 16 @ 3:45 pm
If you plug a new macbook pro into a Denon MC6000 MK2 via USB-C, will you still need to plug the macbook's power supply in to power the computer? I think the USB-C is power as well?
geposted Sun 30 Oct 16 @ 11:31 am
USB-C (is not a new type of USB) is just a new connector that plugs in no matter which way it is rotated. USB always had power in the line.
a lot of companies are making bad usb-c cables and adapters be careful what you buy read the reviews.....
geposted Sun 30 Oct 16 @ 1:42 pm
Controllers that you have to plug in with their own socket anyway could be made to deliver power back to the pc if it supports usb power delivery, but as far as i know there are no controllers that do so yet.
geposted Sun 30 Oct 16 @ 3:47 pm
