Topic: Help Needed Please!!
jono71Home userMember since 2013
Just started using VDJ converting from Serato.
My set up is a 2013 MacBook Pro with 8GB ram with an American Audio VMS5 controller through Alto Active Speakers.
I used 2 weeks ago at a wedding with no issues at all. Last night i had the following issue. After using the auto mix through the right hand side of the mixer deck with no issues as soon as I switched the auto mix function off to mix through both channels ( only using 2 decks ) the left channel played fine but the right hand playback would jump or slightly pause as though I was touching the jog wheel.
Any ideas ?? Is this software issue or hardware ??
geposted Sun 30 Oct 16 @ 11:36 am
