Topic: Loop out not working since 3493?
I've updated to the latest 3493 build and I've noticed that the loop out function doesn't seem to be working like it was before. I usually activate it by using the loop out button on my Numark NS6 controller or the auto loop button on my Pioneer SP1. Anyone's else notice the loops acting differently?
geposted Mon 31 Oct 16 @ 5:50 pm
So, you are talking about the Loop OUT button on the default skins ?
How does it behave now ?
Maybe you have Loop Back mode enabled ?
geposted Mon 31 Oct 16 @ 6:21 pm
Thanks for your response. It was user error! I've just installed a new skin and one deck didn't have smart loop on. On another note though, what would be the script to activate loop out for 16 bars, when I press the loop out button, and exit the loop when I press it again. Thank you.
geposted Mon 31 Oct 16 @ 6:44 pm
loop 64
geposted Mon 31 Oct 16 @ 8:23 pm
Or if you use loop_half and loop_double, you can replace those with loop 50% and loop 200%
geposted Mon 31 Oct 16 @ 8:44 pm
Thanks guys, I'll give these a try.
geposted Mon 31 Oct 16 @ 11:12 pm
