Last night I happened to sort a lot of my new videos with no problems, this morning while continuing to sort (drag into folders) the screen flashed and the program frozed, have to ctrl del to close it. It happens randomly, sometimes after the 10th, 4th, 1st... song that's dragged to the folder. I have not changed anything. I'm not sure right now if also happens with sorting audios since I've only been working with videos to prepare for a video gig.
geposted Sat 05 Nov 16 @ 10:31 am
The only change I made this morning was my default video card, instead of using my pc card, I changed it to default to my high performance 4gb NVIDA video card. I changed it back to my PC integrated card and the problem went away but there is a slight delay/pause when the first video is loaded. The performance with my NVIDA is much better, is this card not recommended?
I'm using the updated version of VDJ.
geposted Sat 05 Nov 16 @ 11:00 am
Before moving files to folders I load on the deck first to prelisten..
geposted Sat 05 Nov 16 @ 11:04 am
Are you moving the videos while still loaded on the deck?
geposted Sat 05 Nov 16 @ 12:22 pm
Guess you can say that. I load the video, hit play and then attempt to move it. Doing the same action under the the other video card does not create the freeze. This is on a Lenovo y70, 16 gig ram, 4gb Nvidia.
geposted Sat 05 Nov 16 @ 3:27 pm
To clarify I'm not moving the physical location of the file. Im adding it to my playlist folders. It even happened a few times when the file was not moved.
geposted Sat 05 Nov 16 @ 3:30 pm
Hello any recommendations to fix this?? It's only happening when virtual dj is using my Nvidia video card.
geposted Sun 06 Nov 16 @ 6:32 pm
