I have defined (manually) a number of POIs on songs in a VDJ8 installation.
My songs are stored in an external usb stick.
A database.xml file exist on that disk.
I move my external disk to another PC with VDJ7 installation.
I notice that a new xml file is created (relative to VDJ7 I suppose).
Automix does not respect the previously (and manually) defined POIs.
Any ideas to maintain them ?
Regards Theodore
Regards Theodore
geposted Sat 05 Nov 16 @ 5:53 pm
I don't think VDJ saves POI's with the songs by default. You might want to copy over your original database XML file.
geposted Sat 05 Nov 16 @ 6:00 pm
It is already saved, but VDJ7 creates a new xml file.
I think VDJ7 does not read the (VDJ8) database.xml but the new one created.
This one of course does not contain the manually defined POIs (on the VDJ8)
geposted Sat 05 Nov 16 @ 6:16 pm
there is a tool to convert 8 database to 7 but you will need to have a license -> http://www.virtualdj.com/plugins/index.html?addonid=80185
geposted Sat 05 Nov 16 @ 7:04 pm
That is correct. VirtualDJ 8 will read and convert a ver 7 database if no ver 8 database is created (so, the first time you use VirtualDJ 8 with a Hard Drive), but not vice versa.
Since you have used Version 8, is there a reason why not keep using that to your other computer ?
geposted Sun 06 Nov 16 @ 3:16 am
VDJ8 is a free version. VDJ7 is a paid version
geposted Sun 06 Nov 16 @ 8:22 am
If you have a full VDJ 7 Pro license then VDJ 8 is a free upgrade. You will however need to register the VDJ 7 license to your account here, so that VDJ 8 will recognise it.
geposted Sun 06 Nov 16 @ 9:14 am
