Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: Numark NV Firmware 1.07
Numark released a new Firmware for Numark NV (not NV II). Firmware 1.07 added BeatGrids to Screens.
Some People say, that Serato-Users have to update the Software also. Is there someone who tested the new Firmware with VDJ 8.2 (Build 3471)
Posted Mon 14 Nov 16 @ 10:52 pm
We will take a look at the new firmware and let u know.how it works.
In the meantime, it is strongly advised not to update to the new firmware until we make sure it doesn't break VirtualDJ compatibility
Posted Tue 15 Nov 16 @ 5:09 am
Ok, Thank you!
Posted Tue 15 Nov 16 @ 7:12 am
hh73PRO InfinityMember since 2006
let me know if it "sounds better" my nv2 sound like im playing underwater in vj8.
Posted Tue 15 Nov 16 @ 4:35 pm
We checked the new firmware and found no issue with VirtualDJ, so its all good to update.
The new firmware supports CBG display on the waveform, and VirtualDJ will offer this in next Build.
The only glitch we found and already informed Numark about, is that when you open VirtualDJ (or Serato), the Hotcue markers of the previously loaded track are still drawn on the progress bar until you load the first track.
Not a showstopper of course, and considering how helpful the CBG may be for some, the firmware update sounds logical to proceed with.
Posted Thu 17 Nov 16 @ 2:59 am
ok cool. thanks djdad
Posted Thu 17 Nov 16 @ 8:06 am
any link to the firmware. seems a bit hard to find?
Posted Thu 17 Nov 16 @ 8:11 am
Posted Thu 17 Nov 16 @ 8:39 am
ATTENTION:
This firmware is NOT for the NV 2 it is for NV 1 !!!
You may break your unit if you try it.
Numark themself writes on the page above:
Note: Do not attempt to install on NVII
Posted Thu 17 Nov 16 @ 2:05 pm
im selling my nv2. im moving and need to cut down. now i am running a pioneer djm t1 with two numark ndx 500s. they are cheap and work great for dvs. my 1200s are packed in storage.
Posted Fri 18 Nov 16 @ 10:37 am
thanks for the headup on the firmware.
Posted Fri 18 Nov 16 @ 11:32 am
i updated to 1.07
works fine fine but doesnt shiw my
track WAV
Posted Fri 18 Nov 16 @ 1:44 pm
i updated to 1.07
works fine fine but doesnt show my
track WAV
Posted Fri 18 Nov 16 @ 1:46 pm
version 8.2 prob will.
Posted Sat 19 Nov 16 @ 10:19 am
Thx. djdad for the News :-)
Posted Sun 20 Nov 16 @ 7:05 pm
Does Numark nv work with virtual dj 7.4 pro
Posted Thu 09 Nov 17 @ 7:04 pm
No, it doesnt. Requires version 8
Posted Thu 09 Nov 17 @ 9:54 pm
