Hi,
Just moved to a new Numark NVII controller - enjoying it very much.
I have a question on the playlist displays - is it possible to see "played tracks" marked in the playlist track list displays on the NVII (they show up as expected on the PC display). Should they show up in another text colour for example ? Or is this a limitation with the current NVII firmware ?
Cheers.
Cheers.
geposted Sat 19 Nov 16 @ 9:07 am
By default, the NVII displays will show the browser colors on the display. (So if you paint your files on VirtualDj browser, you will see the same colors on the screens)
If you wish to change that behavior and see the played tracks instead please do the following:
1) Hold down the "SLICER" pad mode button for more than one second
2) The special NVII settings pad page should appear on VirtualDj GUI and it should be reflected on your controller as well
3) Press the 4th pad named "Show Played" (colored green)
You are done!
Actually due to a bug on the mapper this procedure will be available on the next update of the software.
Until then, use a custom button and add the following action on it:
toggle '@$NV2BRSP'
This action changes whether or not the displays will show the browser colors or the played tracks.
You are done!
toggle '@$NV2BRSP'
geposted Mon 21 Nov 16 @ 9:30 am
Thanks - it is an excellent reply :-)
geposted Mon 21 Nov 16 @ 9:49 am
geposted Mon 21 Nov 16 @ 10:18 am
