Topic: prelisten Output function does not work correctly
Did not get any answers from VDJ support team, so i'll try here.
I use VDJ 8.2 b3523 Pro Infinity usually with dual Pioneer CDJ (350-400-850-900-2000-2000NXS), using 2 USB cables and HID support.
If you are familiar with the 'prelisten' function, you noticed that when you have set up DECK1 & DECK2, the pre listening takes place on the deck that is not currently playing during your set ('prelistenOutput function set to 0 in advanced parameters).
For some unknown reason, the pre listening function does not work for me this way anymore...
(And it used to work perfectly just a month ago).
To work around, I have to setup a 3rd output in the audio menu : 'prelisten' is set to my internal audio card, and I need to link an audio cable to a 3rd entry on the mix table, wich is very annoying and not always possible if only 2 inputs available.
Does anyone have encountered the same issues and managed to fix it?
Any other usefull tips?
Thanks,
Ron.
geposted Sat 03 Dec 16 @ 3:54 pm
