Not a regression bug but i don't remember seeing it a few builds back. I'm on 3542 and when i have a video playing on deck 1. Deck 2 is playing on a loop and i activate milkdrop on deck 2 and i open the options the waveforms become very buggy and basically the whole software.
I'm using:
Windows 10 64 bit Alienware i7 2,6Ghz 16GB RAM 3GB Nvidia 970m
Nothing running in the background.
Skin FPS and Video FPS are at 35
Try moving the options window around and you'll see it buggier
I'm using:
geposted Mon 05 Dec 16 @ 12:20 am
when u say activate milkdrop are you runing as a deck fx or audioOnlyVisualization ?
i was fine as audioOnlyVisualization earlier today on build 3542
geposted Mon 05 Dec 16 @ 12:47 am
Sorry forgot to mention that. I'm using it as a single deck effect. Try what i wrote:
Play a video in deck 1.
Put a video on a loop on deck 2.
Activate milkdrop on deck 2 (as single deck effect)
Open options and move that window around. The waveform become super buggy. When you activate milkdrop at deck 1 at the same time, it becomes even buggier
geposted Mon 05 Dec 16 @ 1:18 am
okay... kinda weird but instead of the waveform being buggy or jumpy it's still smooth when I have an HD video on a loop, milkdrop on one deck as effect, and when I open options to move it around ... options is jumpy moving while the waveform is smooth.
geposted Mon 05 Dec 16 @ 4:00 am
I'll make a video.
geposted Mon 05 Dec 16 @ 6:23 pm
