Hi,
I have a Numark NS7II. Fairly recently, the channel 2 gain fader started misbehaving by not being in sync with the actual controller.
See demo here:
https://youtu.be/EUI5HkkI6H4
The fader on the controller is at the top, but the software is not able to read that properly
I have tried cleaning with a contact cleaner but that has not solved the issue. I did this for the crossfader sometime back and it worked.
Kind regards.
See demo here:
Kind regards.
geposted Tue 06 Dec 16 @ 8:25 pm
Check with midiox, see what readings the slider is kicking out, it maybe fader bleed, dirty contacts, it doesn't look like a floating earth issue.
BTW up faders aren't "gain", gain is amplification, up faders are a gate or a like valve [determines how much of the gained signal is allowed to pass through]
geposted Tue 06 Dec 16 @ 10:16 pm
If the contact cleaner didnt do the job, i would advise you to contact Numark as it appears to be a Hardware issue.
If it was a software one, most likely all Volume faders would act similarly.
geposted Tue 06 Dec 16 @ 11:50 pm
