Here is what I have figured out so far (my legacy = Traktor & iTunes):
PopM Frame = email, rating, counter
iTunes stores ratings in its own database, so nothing in source file in ID3 PopM frame
Traktor is stored with traktor@native-instruments.de as the PopM frame's email + 0 in counter
VDJ is stored with no email address + 0 in counter
(below: PopM rating values for Traktor & VDJ, but iTunes Music Library XML stored value)
Star-Rating Traktor iTunes VDJ
1 51 ? 1
2 102 40 64
3 153 60 128
4 204 80 196
5 255 100 255
There seems to be 3 configuration settings that could affect VDJ's behavior with Rating tags:
1. getTagAuto
2. setTagAuto
3. getRatingFromTags
Plus the default action of VDJ as it reads a new file
Can someone explain what is being read, interpreted, & written relative to Ratings values & PopM frames?
1 51 ? 1
2 102 40 64
3 153 60 128
4 204 80 196
5 255 100 255
1. getTagAuto
2. setTagAuto
geposted Thu 08 Dec 16 @ 1:17 am
Not sure I understand the question, you've shown what is written to the frame above, ie 1, 64, 128, 196 and 255 for ratings 1 through 5 in VDJ, which are the same values used by Windows Explorer. We also use the same read ranges.
See the section 'ID3v2 rating tag issue' here: https://en.wikipedia.org/wiki/ID3
geposted Wed 14 Dec 16 @ 3:19 pm
If a Traktor entry in POPM frame exists, do you read/interpret it since its values are different from what you natively save?
geposted Wed 14 Dec 16 @ 4:58 pm
It will interpret those entries on the scale we use (which is more commonly used) so the rating would be wrong for tracks rated 1 or 2 in Traktor. I will have a look at using the custom Traktor scale if the NI email address is detected.
geposted Wed 14 Dec 16 @ 5:06 pm
