Topic: Looping without stopping
ThelemaPRO InfinityMember since 2010
I'll try to explain this as best as I can, but from all the effects available for download, which one would best allow me to repeat a certain section without looping it, in order to create a build-up going into the next section of a track? Something that would sort of repeat 1/4 of a bar for as long as I wanted to but the track would still progress, as opposed to trying to do that with a loop, where you end up right where you were when you started the loop.
geposted Thu 19 Jan 17 @ 11:45 pm
Turn slip_mode on,
geposted Fri 20 Jan 17 @ 12:04 am
Or map/remap a button to:
loop ? loop_exit & slip_mode off : slip_mode on & loop
geposted Fri 20 Jan 17 @ 2:10 pm
Actually the loop roll fx can do this too, it just needs a script to switch from momentary to latch, I'm surprised the loop roll pad page doesn't already do this, either by mode (switched on a param) or on shift pads.
Since I've done it already would atomix be interested?
Tell me which (param or shiftpad) and I'll submit it. Or I could just post an example if atomix wants to turn it into a pad verb
geposted Fri 20 Jan 17 @ 2:53 pm
I've found that the FilterRoll can do this, but it's tricky because the knob settings are sensitive and can easily go too far or not enough.
geposted Sun 22 Jan 17 @ 2:43 pm
