Topic: Map a button/key to "kill all audio"
idj4uPRO InfinityMember since 2004
Way back in version 4 or 5 I asked about a way to cut the audio on any selected track. The effect I was after went beyond an EQ kill, I wanted to kill the entire channel for a moment, then switch it back on. The effect I'm after is like switching the channel select from LINE to PHONO. Back then, the CUT effect was recommended. I was able to map it to my keyboard at the time, I think it was set to a momentary action - press the key, audio is muted, release and the audio comes back.
Some probably use a crossfader for that. I'm too old and lazy to re-learn that trick.
So back in the older version, all was OK. The new Cut8 fx plugin and similar don't do what I want. It seems to try and cut on or between beats, but I want full control over this.
Is there a way to do this in Version 8.x? I have my reasons for wanting this effect.
Thanks!
geposted Sat 21 Jan 17 @ 6:32 am
read script verbs, you'll see how.
geposted Sat 21 Jan 17 @ 7:19 am
Pretend I have no idea what that means.
geposted Sat 21 Jan 17 @ 9:01 pm
geposted Sat 21 Jan 17 @ 10:31 pm
Thanks! I'll learn how to make that work, seems pretty straight forward kinda.
geposted Sun 22 Jan 17 @ 9:41 am
Hint - look under the 'Audio volumes' section. Penultimate entry.
geposted Sun 22 Jan 17 @ 9:54 am
Thanks. Have a nice day folks!
geposted Mon 23 Jan 17 @ 7:03 am
double post
geposted Mon 23 Jan 17 @ 9:37 am
There's a command there called "mute". Wow. Could that have something to do with it?
...and yes, being grateful and sarcastic simultaneously.
But seriously, this should do the job nicely! Thanks again!
Nick
geposted Mon 23 Jan 17 @ 9:38 am
