Topic: VMS5.0 Skin no Sandbox
humpydPRO InfinityMember since 2016
Hi, Setup VMS5.0, VDJ Pro, i have no Sandbox icon in the skin..... any help out there?
geposted Sun 22 Jan 17 @ 7:24 pm
Default skin.
geposted Sun 22 Jan 17 @ 9:39 pm
4 decks skins dont use the sandbox its only for 2 decks
geposted Sun 22 Jan 17 @ 10:47 pm
Reason why Sandbox was not included in the Limited Edition VMS5 skin is that Sandbox is not working with Ext Mixer Audio setup (which is what the VMS5 needs to properly operate).
geposted Mon 23 Jan 17 @ 10:45 am
thanks for the info, my VDj is not LE, i will try with a 2 deck skin
geposted Tue 24 Jan 17 @ 10:49 am
It doesn't matter if it's LE or not.
What djdad meant above is that since VMS uses "External Mixer" audio setup to work properly, Sandbox cannot be offered.
geposted Tue 24 Jan 17 @ 11:15 am
ok, thanks to you all...., with a 2 deck skin it works
geposted Tue 24 Jan 17 @ 11:48 am
Well that sucks!
geposted Sat 09 Jun 18 @ 10:23 pm
