Forum: Old versions
Topic: DJ We-Go 3 Not Connecting
BH LogicPRO SubscriberMember since 2015
Hello, I was wondering if anyone has had any problems and any luck solving connection issues with the Pioneer DJ We Go products. I have researched previous posts and none of them seemed to be running on Windows 10, as I am. I never had any problems with connections with the controller until the recent update of Virtual DJ that I just added. The controller lights up and powers up, but in the options of the controller settings it is giving a failed to connect. Is there any steps to be able to rectify this issue?
geposted Wed 01 Feb 17 @ 3:02 am
dcomoPRO InfinityMember since 2012
I have a few of the Pioneer Wego units and they all work perfectly fine with VDJ 8.2. Unfortunately, they do not work with VDJ 7.
(The host OS shouldn't matter that much... Windows 7, Windows 8.x, and Windows 10 all work fine.)
geposted Thu 16 Feb 17 @ 5:00 am
Supported controllers for version 7 is here
geposted Sun 19 Feb 17 @ 5:45 pm
