Topic: Fader Start turned on in VDJ 8 after update
FotobroPRO InfinityMember since 2018
Can someone verify what the fader start check boxes should be. After an update, my Ch 1 fader is autostarting the song on that deck. Ch 2 is fine. Yes and No are unchecked. The Per Decks box is checked and the there are 4 boxes on the same line and the first of the four boxes is checked. I checked the "No" box and the Per Deck boxes went away. I'm not near my controller to see if that took care of it, but will report back once I get home if it took care of the issue.
Thanks
geposted Fri 10 Feb 17 @ 8:53 pm
It should be set to "No" if you want Fader Start to be turned off to all decks, so you should be OK now.
geposted Fri 10 Feb 17 @ 10:09 pm
Yep, it did work.
Thanks,
G
geposted Sat 11 Feb 17 @ 3:07 am
