Think I found a flaw with vdj...I'm trying to setup my tracks with all my cues. But i noticed after i set the first cue that i cannot click on other parts of the track to jump ahead, I can only spin the platters to move ahead. I never had this problem with other versions of the software. Is there a work around for this?
geposted Tue 21 Feb 17 @ 5:28 am
Are you using the newest build(3573)
Because I've just tested what you are describing, and if I understand you correctly, I don't have a problem doing this
I've made a small example video:
geposted Tue 21 Feb 17 @ 7:13 am
