8.1 Pro User, using a Behringer Midi controller. You all know the feature where you can do a "pitch-reset" over an amount of time to gradually restore a track to its original BPM.
I'm looking for a command to the opposite. Example... track is playing ... hit a programmed button which will + or - pitch by a given percentage over a measure of time.
Start playing a 123bpm, then hit the button, system gradually takes it to a different percentage over time so that it ends at a different value.
I've experimented with some code but can't get a syntax that works. Ideas?
Thanks
Thanks
geposted Tue 21 Feb 17 @ 7:46 pm
