Heya there guys,
First the situation:
I have a radio show and recently I've created some jingles that I use for an intro and in between songs.
The problem:
I am creating more jingles than my controller (WeGo) can handle so the next step would be to use a soundboard program.
I've been searching on the web and I learned that I would need VAC.
Thing is, I have no clue where to begin with the settings.
Does anyone here have experience on that ?
Hoping to get some help ;)
Stay awesome!
The problem:
Stay awesome!
geposted Fri 24 Feb 17 @ 9:33 am
Just found out about VDJ Remote app, gonna try that out first.
geposted Fri 24 Feb 17 @ 1:15 pm
Why don't you just load the jingles onto VDJ sample pads?
Your WeGO may only have a few sample buttons, but you can load the samples into several banks in VDJ and switch between them.
geposted Fri 24 Feb 17 @ 6:10 pm
