Hi there,
So I've noticed that when I open VDJ 8 (LE), the appearance of it changes and I lose a bunch of features like cover art, side list and I can't view the bpm at the end of a row of the list of songs.
Is this to do with my license or is it a bug?
geposted Sat 25 Feb 17 @ 9:27 am
I'm pretty sure it's not a bug, it's more likely to be related to your license ;-(
geposted Sat 25 Feb 17 @ 10:17 am
That's annoying, I want to use my controller as well :(
geposted Sat 25 Feb 17 @ 10:47 am
it might help if you say what controller you use
according to you avatar you're using a home free version and it's not showing as an LE user
In my opinion in the long run your best bet is to buy the Pro license
geposted Sat 25 Feb 17 @ 10:52 am
I know it's really not much but for now it's okay, I have a numark party mix
geposted Sat 25 Feb 17 @ 11:07 am
I have the same controller and vdj 8.2 le mine does the same but i leave mine pluged in so it starts le for the controller. and when i log in on the forum i also come up as a home user so don't worry about it if you don't like the numark party mix skin change it i did i use v8 by fruit skin it looks good and the controller works with it i hope what i have said helps.
geposted Tue 28 Feb 17 @ 3:04 pm
here's some info
http://www.virtualdj.com/products/virtualdj/comparison.html
geposted Tue 28 Feb 17 @ 10:32 pm
