Topic: Midi play and cue
i12mxPRO InfinityMember since 2013
I have windows 8 my mixer is American dj 10mxr
The problem is the play and cue button do not work.
geposted Thu 16 Mar 17 @ 2:51 am
Do the other MIDI buttons (1/2/SYNC) on the 10MXR work properly ?
Do the PLAY/CUE buttons on the skin play/cue the decks ?
Do the PLAY/CUE buttons of the 10MXR appear in the Key Learn (Right box under the Info button in Settings->Controllers tab) when the 10MXR is selected and press those buttons ?
geposted Thu 16 Mar 17 @ 3:22 am
no they don't work at all i have tried!
geposted Thu 16 Mar 17 @ 10:46 pm
in fact they do work on the skins
geposted Thu 16 Mar 17 @ 11:15 pm
So there is a generic issue with MIDI in general with the unit.. i suppose not even the Volume/EQ faders of the unit move the ones on the skin, right ?
If that is so, you will need to see if there is hardware issue, so try the following..
- Check Windows Device Manager, see if there is any yellow triangle (or other mark) on the MXR unit
- Try a different USB port and/or a different USB cable
- Try a different computer.
- Use Miditrace or MIDIOX to see if the buttons/faders of the unit send any data
Finally contact American Audio support for a possible replacement/fix.
geposted Thu 16 Mar 17 @ 11:36 pm
