Topic: folders can't be deleted
v8.2 b3671 build problem with virtual folders. created new virtual folder and instead of going to the bottom of the file they go straight into list&advice. music can't be transferred nor folders can't be deleted....please help!!!
geposted Sun 09 Apr 17 @ 7:32 pm
they are deleting here on windows? build 3678
are you running a mac possibly?
geposted Sun 09 Apr 17 @ 9:11 pm
is this a new update again since last week
geposted Sun 09 Apr 17 @ 10:08 pm
pc
geposted Sun 09 Apr 17 @ 10:11 pm
here's the release info
BUILD 3678 (2017-03-31)
-Fix creating new filter folders directly in system/virtual folders
-Hide locally unavailable tracks from pulselocker downloaded content folder
-Fix cover art crash on mac
-Send speaker configuration to VST plugin (fixes incorrect channels in Izotope plugin)
-Add zoom parameter to camera plugin
it may be just what you need to sort out the problem
geposted Sun 09 Apr 17 @ 11:25 pm
