As title says, a few buttons aren't doing what there supposed to any longer. For example - the 4 Beat Echo ( by locodog) now just stops the song instead of echoing out.
Below is the script
get_beatpos & param_add 4 & param_cast & set 'EndBeat' & set 'AutoEchoOutFX' 1 & effect_slider 'echo' 1 0.8 & effect_slider 'echo' 2 0.85 & effect_button 'echo' 2 on & effect_active 'echo' on & repeat_start_instant "AutoEchoOff" 1ms & get_var 'EndBeat' & param_smaller get_beatpos ? effect_active "echo" off & pause & set 'AutoEchoOutFX' 0 & repeat_stop "AutoEchoOff" : nothing
Any ideas?
Below is the script
Any ideas?
geposted Sun 16 Apr 17 @ 7:52 pm
Can't test (or hardly see, heavy weekend) check if the trailing button is on the echo fx gui
geposted Sun 16 Apr 17 @ 7:58 pm
It works.
geposted Sun 16 Apr 17 @ 10:52 pm
the same update on my home pc works fine, but the dj laptop it just stops dead, i've checked what locodog says and they are both identical. I'll investigate further
geposted Mon 17 Apr 17 @ 1:27 am
Like I mentioned, the home pc wasn't affected by the update but the dj laptop was. I decided to delete the custom buttons, restart vdj then reinstall the same buttons and boom!, all is good. Consider this solved and clised.
geposted Mon 17 Apr 17 @ 8:39 am
