Topic: Deck security and prgram close will work while playing
Hi i have v8.2 running with a VMS5 and it will let me load a track on to the playing deck and also i can close the program while its playing, my previous install with my VMS 4 would not let me do this. The setting in options is correct any help out there for this ?
geposted Fri 21 Apr 17 @ 8:51 am
Are the VDJ volume faders up when you try to close the program?
geposted Fri 21 Apr 17 @ 1:12 pm
yep faders are up and deck is playing clicking the X closes the program straight away
geposted Fri 21 Apr 17 @ 9:26 pm
I got some info from the facebook group and i will try moving the crossfader off centre, i rarely use the cross fade so its a bit of a pain
geposted Sat 22 Apr 17 @ 9:24 am
