Forum: VirtualDJ Skins
Topic: EKS Otus skins and mappings??
LeharaPRO InfinityMember since 2017
DOES ANYONE HAVE A SKIN FOR THE OTUS?
OR A REVISED MAPPING??
THANKS.
geposted Mon 24 Apr 17 @ 1:50 pm
There's nothing when searching. Not a common controller.
geposted Mon 24 Apr 17 @ 2:13 pm
Having a little look at the unit, it is supposed to come with midi editor software so you can map it yourself to whatever software you want.
geposted Mon 24 Apr 17 @ 2:32 pm
geposted Mon 24 Apr 17 @ 6:20 pm
The OTUS Skin is written in a very old Skin SDK version, and probably will not work properly in VirtualDJ 8.
geposted Tue 25 Apr 17 @ 12:29 am
thank you.
I will give it a try anyway.
thanks for the response people.
geposted Tue 25 Apr 17 @ 1:51 pm
