Topic: Second download
Can I download the free version to a second computer to sort files and have them show up as sorted on the one i use for personal use at home.
I have down time at work to organize my files if I can do this.
geposted Tue 25 Apr 17 @ 7:22 pm
you can download yeah, would suggest you then sync your database folder to google drive or dropbox and then any changes will sync across machines
geposted Tue 25 Apr 17 @ 8:26 pm
....assuming music files are stored in identical locations on both computers.
geposted Tue 25 Apr 17 @ 8:42 pm
That's a good point groovin. Thinking about it, you could just move all your tracks to an external hard drive, VDJ will then automatically create a database folder on the external drive, then hook up the external hard drive to your work computer. You would need to just make sure that your work computer can assign the same drive letter to the external drive. As long as the drive letter isnt in use on your work pc, you can change it on the work computer. Then make whatever changes at work and then move back on home computer.
geposted Tue 25 Apr 17 @ 9:37 pm
The drive letter doesn't matter. VDJ ignores it.
geposted Wed 26 Apr 17 @ 5:23 pm
