Topic: Pioneer DDJ SR issues with certain functions not working
FumpsHome userMember since 2016
Hi guys
I'm having a few nightmares setting up my Pioneer DDJ-SR. After a nightmare of a list of issues to finally get sound through my controller (Not VDJ's fault) I am now having issues with the mapping (I think).
First off I'm still new to all this so please be patient:
The issues I am having is that the master volume knob has no effect and looks as though it needs mapping but am unsure how to do this.
Also the FX knob are not allowing me to select them: the first one works bt the effect carries on playing even after i deselect it.
The other two FX knobs will not light up at all, instead they cycle through the different effects which changes the effect on the first knob.
I have installed all firmware, drivers & mapping from the VDJ site when setting this all up but am now faced with these issues.
I'd really appreciate some help if possible
thanks for your time in reading this
geposted Sat 06 May 17 @ 2:45 pm
Answered in the other thread you have running - here
geposted Sat 06 May 17 @ 2:54 pm
Hi mate
Yes with these new issues I'm finding I thought it would be better to start a new thread.
Yes the volume knob doesn't change the volume at all.
geposted Sat 06 May 17 @ 3:31 pm
Fumps wrote :
Hi mate
The action of the second and third effect button in the default mapping depends on if you are in 3-slots layout:
Button 2: effect_3slots_layout ? effect 2 active : effect select -1
Button 3: effect_3slots_layout ? effect 3 active : effect select +1
So if you are in 1-slot mode they cycle the effects. If you are in 3-slot mode they turn on and off effect 2 and 3
You can try changing your mode by making sure you are using the default skin, and clicking the header of the effect block
geposted Sat 06 May 17 @ 9:47 pm
klausmogensen wrote :
Fumps wrote :
Hi mate
Thanks so much for your reply.
I'm steadily getting it back to the original settings and layout, its been a hard slog for someone like me who has no idea how to change this kind of stuff, but i'm getting there.
Thanks again for all your help & advice.
geposted Wed 10 May 17 @ 9:52 am
