Hello,
I did not find this in the discussion, so I want to ask for it - i am using the Standard Skin, but this feature should be globally useful in my opinion.
I play around with the visible columns in my playlists and there is a annoying usability problem: when I add a new column (e.g. comments) and put it among other colums, I have to refit all columns by hand, to give room for the new one/keep the size of the existing ones. This is very complicated and makes finding the proper setup very hard. Especially the well adjustet BPM column (for having the bar instead of difference count) must be re-adjusted every time.
Can this be improved please or, moreover, brought to the established behaviour like in file explorers in Windows, Linux, Mac etc. Would be veeery helpful :)
Thanks and greetings!
geposted Tue 09 May 17 @ 10:42 am
please close this post, seems to be wrong here and i don't want to doublepost. thx.
geposted Tue 09 May 17 @ 8:52 pm
But you just have - in CAPITAL LETTERS too.
https://www.virtualdj.com/forums/217686/VirtualDJ_8_2_Technical_Support/REQUEST__RELATIVE_RESIZING_OF_BROWSER_COLUMNS_(PLAYLIST_E_G_).html
geposted Tue 09 May 17 @ 9:00 pm
