I would like a screen similar to the one I've been using for years. Vmix , the advantage is , I can create a preview screen for each deck and a larger center screen for viewing. Please help me locate one so I can change to version 8, thank you in advance. Michael
geposted Sat 13 May 17 @ 7:39 am
Have you looked in the VDJ8 skin download section? Just type in video in the search box, there's several available.
geposted Sat 13 May 17 @ 8:05 am
michaelhawkins1 wrote :
Vmix
Which one? There are lots of variations in the download area.
Old skins can usually be modified (old XML updated) so they work on VDJ 8.
[thinking] it would be nice if there was a tool that did this - scan the XML and update the old code to new.
geposted Sat 13 May 17 @ 9:41 am
I would give this one a try:
http://www.virtualdj.com/plugins/index.html?filter=8&page=2&search=focus
geposted Sat 13 May 17 @ 12:13 pm
I love that one also, just wish it had Harmonic display.
geposted Sat 13 May 17 @ 8:08 pm
Focus is the best skin for video mixing! try that one......
geposted Sat 13 May 17 @ 11:28 pm
+1 for Focus
geposted Mon 15 May 17 @ 8:10 am
Focus got an update and Key value display is now available among a few more additions.
geposted Mon 15 May 17 @ 8:59 am
gentleman... I just wanted to thank you for your suggestions. I'm on my way to a convention and should have time to review and maybe experiment with. The support here is why I purchased Virtual DJ. Michael aka DJ T-rex aka Older than dirt etc.
geposted Mon 15 May 17 @ 2:33 pm
Thank you, DJdad. Just tried and it's the shet, will be used tonight.
geposted Mon 15 May 17 @ 8:08 pm
Using it tonight and it's a great skin. Thanks Babis!
geposted Mon 15 May 17 @ 8:55 pm
What is that monitor that you have on the left?
geposted Mon 15 May 17 @ 10:11 pm
http://www.icitouchtech.com/1101p
Mounted on a small camera tripod. Picture quality is outstanding.
geposted Mon 15 May 17 @ 10:26 pm
should be for $400
not sure how u justified such an expense for such a small screen
maybe you use it for other stuff i hope :-)
geposted Mon 15 May 17 @ 10:30 pm
Most other small monitors are low resolution with bad viewing angles. This one is lightweight, runs off a portable battery pack if needed and the picture is superb. Worth every penny.
geposted Mon 15 May 17 @ 11:04 pm
Thanks for the link. I will look for a deal some where, as I just bought a used 27 inch monitor for $100.00.
geposted Tue 16 May 17 @ 2:16 am
just curious , would anyone be interested in updating the V-mix 5.3 so it can be used with version 8?
geposted Thu 25 May 17 @ 12:09 am
