Forum: Music discussion
Topic: Convert to MP3
Hi, I downloaded Virtual DJ free version, so I could chop & slow some tracks, but now i can't figure out how to convert my recordings to MP3, Please help me. Thank you!
geposted Sun 21 May 17 @ 8:13 am
What makes you think your recordings (Of what? From where?) need to be converted?
Unless they're in a very unusual file format, they should play fine as they are. What format are they in? Did you try playing them?
geposted Sun 21 May 17 @ 9:02 am
groovindj, thanks for the response, maybe I didn't word it correctly, but I just found the answer to what I was looking for on Youtube video "Recording Overview - VirtualDJ 8"
geposted Sun 21 May 17 @ 11:09 am
can someone help me to convert the music I bought through virtualDj8 (iDJPoll, Remixes and Audio Pro) with the code file ".vdjcache" to mp3
geposted Fri 14 Jun 19 @ 11:26 pm
You can't buy music through VDJ.
If you're using Content Unlimited then you're renting the music. It doesn't belong to you.
Because it's not owned by you, it's copy protected and cannot be recorded. If you want to own music for DJing, you need to buy it.
geposted Fri 14 Jun 19 @ 11:35 pm
Nobody should pay IDJPoll remixes because it is a scam be careful ... they are thieves because they do not let you download the music and worse still record the music in your VirtualDj program and when you do not keep paying you take away the music that you saved when downloading cache . And even worse, it is only for the United States music and not for the world.
geposted Sat 15 Jun 19 @ 4:04 am
geposted Sat 15 Jun 19 @ 6:49 am
COME FACCIO CONVERTIRE MUSICA MP 3 E INSERIRE NEL VIRTUAL DJ
geposted Fri 16 Aug 19 @ 10:09 am
A little help...
bought into the music subscription two weeks ago , and now when loading it won't play
get a "license expired ?" next to "error"....
geposted Thu 22 Aug 19 @ 6:48 pm
I went thru this a couple of times. If you want to play songs you downloaded to use offline, you may need to login the same day of an event and let the website update your collection of offline downloads. And logging in reads your subscription renewal. Otherwise you get a message that your license is expired. I login the morning I need to use VDJ to make sure I have no issues with license and offline download cache.
geposted Mon 09 Sep 19 @ 8:11 pm
hi i need to set my virtual dl just to down load music is that posible
geposted Tue 03 May 22 @ 6:12 pm
