Hello,
First I want to thank you all for helping me regarding the issues I have with VirtualDJ and my setup is starting to run smoothly.
On my Behringer CMD DC-1 I use a button press to change the rotary knobs with a set of samples to be able to adjust the volumes. When the toggle is off the knobs will be used to adjust sampler volumes 1-8 and when it's on it changes to sampler volumes 9-16. I'm having an issues with writing a script using "active_deck" and variables. I've included a screen shot so you can see the script. Maybe I'm writing it wrong? I don't know..
best free photo hosting
Also a picture of my DJ kit. I built the case myself and the mic/headphones are completely wireless :D
upload photo internet
geposted Fri 26 May 17 @ 5:25 am
Change all instances of 'toggle' to 'var'
Perhaps make your var global by starting the name with $.
geposted Fri 26 May 17 @ 5:45 am
Thank you for your help, but I'm having no luck with this solution. I get the same results.. You got any other ideas? Thank you.
geposted Fri 26 May 17 @ 6:36 am
var_equal '$SamplerVolumeChange' 0 ? action_deck 1 ? sampler_volume 1 : action_deck 2 ? sampler_volume 2 : action_deck 3 ? sampler_volume 3 : sampler_volume 4 : action_deck 1 ? sampler_volume 5 : action_deck 2 ? sampler_volume 6 : action_deck 3 ? sampler_volume 7 : sampler_volume 8
For this script to work, your toggle button must use this script:
toggle '$SamplerVolumeChange'
geposted Fri 26 May 17 @ 7:20 am
This worked perfectly. Thank you.
geposted Fri 26 May 17 @ 8:12 am
