Topic: POIs, loops and actions question.
I just purchased 8 a few days ago and am familiarizing myself the POIs editor. I've successfully created a saved loop with the loop_load action so it will loop automatically. My question is; is there an action command that will play the loop x number of times and disengage automatically from loop mode?
i.e. 8 beat loop played 4 times (32 beats total).
geposted Fri 26 May 17 @ 7:11 am
No, not at this moment.
You can use some funky scripting to achieve this, but it's far too complex even for users that are already familiar with the scripting capabilities of VirtualDj.
geposted Fri 26 May 17 @ 7:25 am
Thanks for the reply. I had a feeling that was going to be the answer. Oh well. I'll just have to disengage the loop manually.
geposted Fri 26 May 17 @ 7:34 am
